LV8: Diagram Disable Structure
I am converting my test code from the use of traditional DAQ to DAQmx. In a couple of my test VIs I have the Traditional DAQ VI for Port Config. if I put those in a disable structure marked as disabled will it cause any issues when running using DAQmx drivers? I don't think it should since it does not get executed but I wanted to confirm.
Once I verify my DAQmx changes work, I will remove it.
Jeff D.
Certified Architect LabVIEW Champion DQMH Framework
(2,732 Views)
Hi Jeff,
That's right, any code in the disabled state of a Diagram Disable Structure does not get compiled or linked to by the owning VI.  You should be safe.
-D
(2,731 Views)
Yeah I figured that was the case.. just wanted to double check
thanks!!!!
Jeff D.
(2,724 Views)
