LV8 Save as Dialog
am I the only one that is driven nuts by the Save as option?
I have a vi open in memory and I want to save it as another name and every time I get the new dialog I see Red,  I know what I want to do, and half the time I cant figure out how to get the new dialog to do what I used to do almost without having to think about it.
Ever time I get this I shut all vis, and Go to windows to do the copy or I have to open it with labview make changes roll the dice to see if I get the dialog to do what I want.
There must be a way to ether get the old dialog as the default,  or give me a button that lets me do what I want.  This has got to be one of the most agravating things in LV8x and its still in LV8.5
ARGGGG
(Venting)
(3,226 Views)
I don't see you problem?
Select "Save as" then "copy" radio button.
Then "Open additional copy" select whether or not the new copy should be added to the current project/library and press "Continue...".
The "Create unopened disk copy" will also not replace the old one, but make a copy on disk without opening it.
This will open a new copy in memory and also leave to old one in memory. It doesn't replace the old as the "Substitute copy for original"  will do.
André
André (CLA, CLED)
(3,208 Views)
