LV8.x Color Box "Value Change" event is firing twice
In LV 8.x, the "Value Change" event for a Color Box is firing twice.  Run the attached VI and select a different colour - you should see two points on the chart.  Interestingly, writing to the "Value (Signaling)" property only causes the event to fire once.  I'm guessing this bug was perhaps introduced when the weird window switching caused by the colour selector in LV 7 was fixed?
Jaegen
P.S. Where is the localized Canadian version of LabVIEW? I want "colour", not "color" Smiley Very HappySmiley Very HappySmiley Very Happy
(4,132 Views)
Jaegen,
I tried this out for myself and verified this behavior that you are seeing.  I'm going to file a corrective action request for this bug so hopefully it will get fixed in the next version of Labview.  Thanks for the feedback!
Justin D
(4,096 Views)
Hmmm - I wonder if it's because you actually click on it twice - once to open the colour selector and then again to select the colour...
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(4,060 Views)
Jaegen,
This was reported to R&D (# 42FC9DIQ) for further investigation.
Justin D
(4,001 Views)
