LV86: Problem to build VI with Conditional Disable Structure and Enhance DSC Support
Hi all,
I have met a problem (in LV86) to build an executable from a project that need Enhanced DSC Runtime support and some VIs use Conditional Disable Structure. A very simple example is attached. More problem description presents on the VI FP. Can anybody test it? I am wonder if it is a LV bug or a problem on my PC
(3,616 Views)
Hi kostya,
I checked into this issue and it looks like a Corrective Action Request (CAR) has been filed with R&D here at NI. That means the problem has been brought to our attention. I would be unable to find out if this issue were to be fixed in future issues of LabVIEW.
As a workaround, you'd simply need to not use conditional disable structures in your LabVIEW program.
Dan Richards
Certified LabVIEW Developer
(3,585 Views)
All,
That CAR #, for future reference, is 131621.
Dan Richards
(3,486 Views)
