LVBrokerAux71
I am trying to open "DAQ Assistant" vi from Express Input pallet.  When i tried to open the VI, it prompts the following error msg: " Unable to locate LabView Run-Time Engine.  LVBrokerAux71 requires a version 7.1(or compatible) LabView Run-Time engine.  Please contact the vendor of LVBrokerAux71 to correct this problem.".
I am currently using LabView 8.
(3,864 Views)
mnk,
Please make sure that you have DAQmx v8.0 installed.  You can check what version of DAQmx you have by expanding the Software list in Measurement and Automation Explorer (MAX) and looking for NI-DAQmx.  If you click on this item, the version will be displayed on the right.  If you do not have version 8.0, please download it from the following website:
If that doesn't help, you should try uninstalling and reinstalling both LabVIEW 8.0 and DAQmx 8.0.  LabVIEW will need to be installed first before the DAQmx driver.  If your Run-Time Engine has somehow become corrupted, this should fix the problem.
(3,839 Views)
I am using Labview 7 Express, Full development system and I got the same error... the link you mention is not there
(3,374 Views)
Here is the correct link, hope this helps.
(3,348 Views)
