LVClass constructor in an XControl's Init.vi crashes LabVIEW when VI using XControl is loaded outside of project
Example attached.
To reproduce behavior,
1) Load "XControl and Class.lvproj", and then "Test XControl with Class.vi"  - everything will be normal, running the Test VI will make the lights blink happily.
2) Close "XControl and Class.lvproj"
3) Load "Test XControl with Class.vi" - without the Project being open - and LabVIEW will crash with an Access Violation.
Conputer:
* LabVIEW 8.2.1
* Windows XP SP2
* Pentium4 2.8GHz
* 512MB RAM
(3,618 Views)
And, of course, I neglected to attach the file.
Attachment included this time.
(3,610 Views)
This was reported to R&D for further investigation. I will post the CAR ID once it goes through the system.  Thanks for the feedback!
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
(3,590 Views)
This was reported to R&D (# 4BPH32XP) for further investigation.  Thanks again for the feedback!
Daniel Eaton
Systems Engineering
(3,580 Views)
