LVCompare Invoke Node Error
I am trying to call LVCompare by inputting this into cmd:
"C:\Program Files (x86)\National Instruments\Shared\LabVIEW Compare\LVCompare.exe" “C:\users\Temp\datalocation1\orange NEW.vi” “C:\users\Temp\datalocation2\orange.vi” –lvpath "C:\Program Files (x86)\National Instruments\LabVIEW 2011\LabVIEW.exe" –nobdcosm -nobdpos -nofppos
But I receive an error message that says:
"An error occurred while running LVCompare.
Invoke Node in LVCompare.vi
<APPEND>
Method Name: <b>User Interaction:Compare VIs</b>"
Has anyone else received this error? How do I fix this?
Thank you!
Amanda
(4,562 Views)
Seems you are using  LabVIEW Full Development system to run  LVCompare.exe.
C:\Program Files (x86)\National Instruments\Shared\LabVIEW Compare\LVCompare.exe will only work with a LabVIEW Professional Development system.
in order to use it you will need to upgrade to the LabVIEW Professional Development system.
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
(4,537 Views)
