LVDT Calibration w/ THORLABS Linear Stage & Laser Interferometer
I am working on a project where I need to calibrate an LVDT.
I am using a THORLABS Linear Stage (DDS050) with a KBD101 motor controller to calibrate an LVDT using a laser interferometer as a reference sensor.
I have a basic code provided from THORLABS to move the sensor however I am now in need of help to move the linear stage and collect data from the LVDT measurement and the reference sensor measurement and compare these until the LVDT is calibrated and then create a calibration curve.
Thank you and I will get all the help I can get,
LabVIEW_Nooob
Message 1 of 1
(763 Views)
