LVMesa.framework documentation
Where can I find the LVMesa.framework documentation? I trying to use this library but without the functions arguments it's almost impossible.
Thanks for the help.
Marc
(3,050 Views)
What do you mean by "the VLMesa.framework"? What do you want to do with it?
LabVIEW uses mesa to draw 3d stuff. The mesa API is descriped here http://www.mesa3d.org/ and here http://www.opengl.org/ .
Wiebe.
(3,042 Views)
Thanks, for the help, I found the documentation easly thanks to you.
I need Mesa in order to get the opengl matrix, because I use a library that modifies opengl matrix to give an object position (the object is in an image taken by a camera). There is no oder way to get the object position so I need opengl....
(3,039 Views)
