LVOO & AF Crash
I have a problem with removing class attributes. There is one class from whom some other classes inherit, which objects are in a lot of VI's and changing something requires updating about 100 VI's. After deleting from this class one attribute, everything looks ok, but when I run application LabVIEW crashes and says 'We apologize...'
I tried a hundred times on two different computers and a hundred times LabVIEW died after that.
I enclose zipped movie showing my problem.
(3,662 Views)
Without watching your movie my first thought is to try a mass compile.  If it succeeds it'll probably fix the problem.  If it fails it should give you a list of VI names to start checking.
(3,650 Views)
Thanks for response. I did mass compile and now I know that I have 138 Bad VIs, and 1326 Bad SubVIs 😄
I hadn't idea that my project is soooo huge 🙂
(3,625 Views)
I found the same problem when I edite typedef Cluster, which is in a lot of VIs. This time during compilation LabVIEW updates all VIs but still crashes when I run my application. Mass Compile doesn't change anything.
Any idea how to solve it?
(3,593 Views)
Accepted by topic author Góras
Hi Goras,
could you try recreating the typedef cluster but without using the original one? I mean creating it from scratch without copying anything? It might possibly get you a little further (and recompile the code afterwards).
Jano
(3,573 Views)
Jano it works!
Thank you very very very much 😄
Góras
(3,530 Views)
Hi Góras,
I'm glad It helped 🙂
Jano
(3,511 Views)
