LVRT 82583V support
Is the Intel ethernet chipset 82583V supported by LV RT? If not, is there a beta driver or planned future support for that chipset?
Thanks.
Luca
(3,110 Views)
Hello Luca,
While support for additional chipsets is what we hope to achieve, it still requires us to manually test the chipsets for compatibility. There is an article where you can find which ethernet chipsets are officially supported. You can find this article in the following link:
Requirements for Desktop PCs as LabVIEW Real-Time Targets:
https://www.ni.com/en/support/documentation/supplemental/08/requirements-for-desktop-pcs-as-phar-lap...
As you can see there is no indication that the Intel ethernet chipset 82583V is supported. However, I found an other article that explains how to add LabVIEW Real-Time support for an Intel Gigabit Ethernet Chipset manually. Of course that means that you will have to test manually the chipset for compatibility. Can you please take a look?
How Do I Add LabVIEW Real-Time Support For an Intel® Gigabit Ethernet Chipset?
http://digital.ni.com/public.nsf/allkb/8677AD0A928D1EA2862574EA007AB2D6?OpenDocument
Saluti!
Antonios
(3,104 Views)
