LVRefNum in CIN, how to?
Hi All,
How I can reach to data via LVRefNum in CIN module? I not found any real solutions in this forum........ 😞
Help, please.
Oleg
(3,176 Views)
@OlegUA wrote:
Hi All,
Help, please.
LVRefNum is just a private datatype tha can represent a number of different refnums, so you should be more specific what you are trying to do. If the LVRefNum you are refering too is a generic file refnum you can use the FRefNumToFD function to return the low level File Manager refnum and then you can use the FMRead, FMWrite, FMTell, and FMSeek functions to access the file.
But in general it is a bad idea to do File access in a CIN. Doing it in the LabVIEW diagram is platform independant, just as powerful and much easier to debug and program.
Rolf Kalbermatter
Message Edited by rolfk on 02-02-2006 09:15 PM
Rolf Kalbermatter  My Blog
(3,178 Views)
Hi Rolf,
I want create the CIN which allocates memory for cluster and returns refnum on it. For example, like "Create User Event", "Create Notifier", and similar. This CIN must allocate new memory  per every call.
Oleg.
(3,168 Views)
@OlegUA wrote:
Hi Rolf,
Oleg.
You can't create User Event, Notifiers etc refnums in a CIN. The functions for this are not exported from the LabVIEW kernel to your CIN.
Rolf Kalbermatter
(3,169 Views)
It's bad news... It was last hope for resolve of problem described here
Thanks in any case, Oleg.
(3,156 Views)
