LVRefNum in a CIN file descriptor difficulties
I am currently developing an application that uses labview and IMAQ to acquire images from a 1429 cameralink capture card.
We aim to analyse the images using some previously devoped c code. Our complications come when trying to access the images
from within a c interface node, where we are having difficulty in obtaining the file descriptors for each image.
typedef struct {
 int32 dimSize;
 LVRefNum ImageOut[1];
 } TD1;
typedef TD1 **TD1Hdl;
MgErr CINRun(TD1Hdl ImagesOut, uInt32 *ROIWidth, uInt32 *ROIHeight,
 TD2Hdl arg1, TD3Hdl arg2)
  File fd;
  LVRefNum *thisrefnum;
  uInt8 *target;
  int32 numread;
  int32 frames;
  MgErr test;
  frames=(*ImagesOut)->dimSize;
  thisrefnum=(*ImagesOut)->ImageOut;
  test=FRefNumToFD(thisrefnum[0], &fd);
  if(test==mgArgErr)DbgPrintf("mgArgErr");
An error is reported by FRefNumToFD ie i don't pass a valid refnum. Does anyone have any ideas what I done wrong?
Any suggestions much appreciated.
Ben
(2,306 Views)
Hi Frisson,
  you've posted this question three times. I'm pointing this forum to the first posting in LabVIEW you made so we can do this in one place
http://forums.ni.com/ni/board/message?board.id=170&message.id=150718
Sacha Emery
National Instruments (UK)
// it takes almost no time to rate an answer Smiley Wink
(2,293 Views)
