LVRuntime Eng 25-2-2010
Hi Johan,
what do you expect us to do with the manual of the stepper motor driver?
(We still cannot check your hardware!)
Message 41 of 44
(649 Views)
There is nothing wrong with the hardware.
Need help with Fotolux programs.
Mvg
Message 42 of 44
(641 Views)
Hi Johan,
so you are able to run those executables by now?
Have you installed all RunTimeEngines as needed?
Are there any other errors popping up?
Which help do you need?
When it comes to debugging:
Install the LabVIEW7.1 IDE (or maybe a newer LabVIEW version). Then start to debug your VIs…
Again: we don't have your hardware so you need to do the debugging on your own!
Message 43 of 44
(639 Views)
got an email from national instruments if it solved my problem.
No is the answer.
wants to debug the PC but cannot download Windows Dbg.
is there any other good program for debugging.
Mvg
Message 44 of 44
(614 Views)
