Lab VIEW 2009 + Mathcad 14
Hi Buddy,
I have a big issue with my new Program.
I would like to connect LabVIEW 2009 and Mathcad 14. It's possible?
I have no idea how can I do. I downloaded from ni.zone a Mathcad Script Wizard.
But I can't find too much information about this. Maybe someone has worked with this?
I need a simple example and I can't found this.
Thanks for advance
Kind regards,Tom
(4,093 Views)
Dear Wuja,
what do you mean by "connecting LabVIEW and Mathcad"? Could you tell me more about what you are trying to achieve?
Do you want to access LabVIEW functionality from Matchcad or do you need a Matcad interface in LabVIEW?
(4,059 Views)
Dear Mateusz,
Thanks for your Kindly reply.
I try to make a one Program to measurement of  the Pressure and Temperature. Then it will be great to send this measurements to MathCad. I have a really big issue with this. I try to use a Mathcad Script Wizard but I can't connected these programs.
Thanks for advance
Kind regards,Tom
(4,043 Views)
I am quite sure your problem can be solved using Labview. So in order to help you. Just post your math problem. By the way. You are abusing locale variables. They are NOT pointers but rather copies of your data. Have you looked at some online tutorials. I think it may do you good
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(4,032 Views)
thank you for your kindly reply.
Please find enlosed this math problem.
This is a first part of calculation.
I should use a Mathcad Script Wizard or Mathcad Interface VI's.
I tried connect these  programs with Mathcad Script Wizard, but unfortunately dosen't work. Now I try to use this second solve. I should use a open/read/close structure? To calculation I need this data from the measurement (LabVIEW): Δp.1,  Δp.0,1,  Δp.2,  Δp.3,  Δp.4 and t.1, t.2, t.3, t.4. It's possible to send  solved data from Mathcad to LabVIEW?
Thanks for advance.
Kind regards,Tom
(4,011 Views)
Dear Tom,
Mathcad Script Wizard and Mathcad Interface VIs are different things and are used in different situations.
From what you wrote I understand, that you need MSW. The problems you are experiencing might come from the fact, that MSW was written in LabVIEW 7.1 and not developed any further.
If you could write exactly what kind of trouble you are having (maybe post some screenshots) it would be great. I will try to install Mathcad and play with MSW.
(3,986 Views)
