Lab VIEW's bar graph
If we create a bar graph that represents negative values in Lab VIEW, it will be drawn in a form that extends downward from the vertical axis 0.
Is it possible to draw a bar graph that extends upward from -100, for example?
(2,078 Views)
Accepted by topic author lesprs
If you don't mind connected bars and want to stop at a minimum value that isn't the bottom of the display, set to the midpoint nearest interpolation and set a second plot to the minimum value you want to fill to. You can then set the fill baseline option to the other plot:
If you want separated bars then you can just set fill baseline option to -Infinity and it'll fill to the bottom of the display, not to zero:
~ Helping pave the path to long-term living and thriving in space. ~
(2,064 Views)
Dear lluminatedG
thank you for your prompt answer!
I understand the content.
(2,046 Views)
