Lab View FTP Put File
Ok I'll try that when I get a chance, thanks
Message 11 of 12
(1,179 Views)
Ok, it works now. Apparently the problem was also that I was running the VI ON the camera itself, so when I put C:\FTP Share as the destination folder, it didn't know what to do because it was trying to find FTP Share on it's own C:\ drive. And I now understand the reason you would use FTP Put File is so that you can transfer the files in the same VI that you are capturing and saving the images in. Thanks for your help.
Message 12 of 12
(1,168 Views)
