Lab View crashes when I add element to cluster
Hi guys,
My program is quite large, so I try to explain my core problem. When I add a new element in the cluster called "Summary" it obviously generates an error.
But when I start to run the program, bearing in mind that the program should show me the occured errors, LabView 8.5 crashes.
This cluster has about 160 elements,18 local variables,which are distrubuted in the whole program and its information is used in different SubVi's.
It's strange that my other clusters react normally according to that problem and the program doesn't crash.
What could the problem be?
Cheers, Nobby
(2,717 Views)
Hi Nobby_83,
which error messages did you get? How can you run your vi, if you got some errors?
Mike
(2,715 Views)
Hi Nobby,
what answer do you expect?
All we know is that you named your cluster "Summary". We neither have a vi attached nor the cluster typedef... And you don't give any error description (apart from "it crashes")...
All I can say is: probably you have some overuse of local variables Smiley Wink
(2,711 Views)
