Lab view Application with a Customized Title bar
I am using Labview 2013. I need to change the color of the Application Title Bar to Black. I dug around quite a lot but did not come across any method to do this. Any suggestions or ideas?
Abel.
(4,521 Views)
You can hide the title bar using VI properties or a property node but to change the color I believe you will need a Windows API call.
(4,514 Views)
Hello Abel,
You should not dug any where else except NI Website. Your query is already been answered on NI Website. Just click here and "http://digital.ni.com/public.nsf/allkb/3155A70B46F115C98625769C007E962E" this may give you some detailed idea for which you are looking for. Kudos are most welcome.
Vinal Gandhi, CLA
(4,495 Views)
Hey Vinal,
Many thanks for your reply. I went through this but the main problem with this approach is that it is going to change the color of all open applications. I was lookinng for a labview specific propery node that will just change the color of the Labview application title bar without affecting other windows. But i believe that is not possible.
Best Regards,
Abel.
(4,448 Views)
