LabJack U12 on LabView for Linux
Curious if anyone has successfully used a LabJack U12 on LabVIEW for Linux.  If so I am in need of some direction.
(3,430 Views)
Howdy jmcbee,
You might want to check out the post here and see if that answers your questions.  Please post back if you still need any additional help.
Sincerely,
Chris G in AE
(3,402 Views)
Thank you for the reply.  My question was more with regards to using a labjack on Labview for linux.  After some investigation it seems like my best bet is to use the call library function node from labview, calling c code that is available for the labjack.
(3,397 Views)
