LabVIEW开发商业应用程序,需要购买哪些证书
大家好,
我想请教一下,如果想用LabVIEW开发一个商用应用,也就是说用LabVIEW生成一个exe可执行文件,并安装在商业用途的电脑上。需要购买哪些证书?
这个购买证书的数量和程序安装的次数(在多台电脑上同时安装使用上述程序)是否相关?
非常感谢。
祝好
(491 Views)
To build LabVIEW applications (exe), you need a LabVIEW Professional license. Once you build the application, you don't need any license (royalty-free) to distribute and use the exe.
https://www.ni.com/en/shop/labview/select-edition.html
Santhosh
Soliton Technologies
(479 Views)
Thank you very much for such a detailed and quick answer!
Best regards
(429 Views)
You can also (or could) buy the Application builder license separately so you can technically have the Base version and build .exe with that. Although, you'd be missing some useful function.
Qestit Systems
Certified-LabVIEW-Developer
(424 Views)
