LabVIEW 2 plug in missing
I just got the latest LabVIEW 2. I can open LabVIEW 8.2 VIs without problems, but when I specifically try to open LV 6.1 VIs I got an error indicating a missing plugin (see image attached). However, I can't find the plug in at NIs website. Is the plug in available?
Message Edited by Enrique on 03-31-2007 11:43 PM
www.vartortech.com
(3,390 Views)
Yes, I had som issues as well.
It keeps mixing up the Barbie Engineer Addon and the Espresso Addon, so now I got coffee with Botox in it.... bummer.
Ton
My LabVIEW Ideas
(3,380 Views)
That's nothing compared to the problems I had trying to update from version 1.0 to 2.0 of the Spousal Acquisition Toolkit so that I could take advantage of the Undo feature.
(3,368 Views)
Smiley HappyHi Enrique
I know this forum it's made for labview 2 but, i've tried to contact you but i couldn't just to ask you one question, do you know where or how i can get the biometrics VIEW? i've tried your page but i don't know how, i need it cause i'm doing an Intelligent Wheelchair (IWs) as a project, this IWs it has to be controlled by the facial gestures of the user, i have a little robot i designed with the a microcontroller but i have trouble detecting face, any tip, book or technique you could tell me?Smiley Tongue
(3,260 Views)
