LabVIEW 2009 Build Path Problem
[Cross Posted to LAVA]
I had some code that worked fine on my home PC, when I moved it to work, the exe would not build due to errors.
The errors coming back weren't that good at explaining the problem
Until I got this one:
Look at the path in the error:
C:\Users\Developer2\Desktop\User Group Meeting\LabVIEW 2009 new features\code\02 intermediate\01 build specifications\build executable file paths\dist\application 9.0\my application.exe\LabVIEW 2009\vi.lib\addons\_ICON Library\String\_icon_lib_string.llb
That path is referring to a VI inside my executable!
This may be a bigger issue that I first thought
So my question is:
If a have a path inside my build that would be relative to the executable and LabVIEW needs to resolve it, could that process fail depending on where the exe sits in a folder hierarchy?
I guess this could have happened before? but it would be more likely now due longer paths!
Message Edited by jg-code on 08-26-2009 05:20 AM
Certified LabVIEW Architect * LabVIEW Champion
(3,848 Views)
Accepted by topic author jgcode
Solution in cross post
(3,823 Views)
