LabVIEW 2009 Remote Front Panel Browser Plugins for Windows / OS X / Linux
All,
    Where can I find the updated web plugins to support remote front panels written in LabVIEW 2009 for Windows/Linux/OS X?
    All I've found so far is this which doesn't even include support for 8.5/8.6. http://digital.ni.com/public.nsf/allkb/151BE12C055F57CE86257043006CB4B3
Thanks!
- Ken
(3,545 Views)
Hi Ken,
Did you try the plugins attached on this page and they aren't working?
(3,543 Views)
They don't work with VIs built with 2009! I just installed the 2009 Run Time Engine for OS X. 32MB download, 111MB installed, not too bad. Installed the proper plugin. Works in Firefox, but shouldn't it work in Safari too?
- Ken
(3,538 Views)
It should work in Safari as well. Which version of Safari are you using?
And when you say it doesn't work, what is happening? Do you get the message that says you need a plug-in? or does the page not load?
(3,510 Views)
