LabVIEW 2009 application installer
Try this
http://nsis.sourceforge.net/Main_Page
- James
Using LV 2012 on Windows 7 64 bit
Message 11 of 12
(662 Views)
Rickygolf,
It is possible to disable both of these dialogs, but there is currently not a way in the LV UI to do this. I think you can do what you want by making a simple edit to the setup.ini of the generated installer.
To disable these dialogs:
  1. Open the setup.ini in a text editor, like Notepad. This file is located at the root of the installer that LV generated.
  2. Find the [Dialogs] section in that setup.ini file.
  3. Find the tag that says "License=1", and change that value to 0.
  4. Find the tag that says "SingleDirectory=1", and change that value to 0.
You'll have to do this every time you rebuild the installer, but maybe that's not too bad.
Be aware that even though you are hiding the NI EULA, you and your customers are still bound by its legal requirements.
- Wes / NI
Message 12 of 12
(639 Views)
