LabVIEW 2010
I have converted some code from LabVIEW 7.1 to 2010.
When I create a Project it includes folders which have not been used on my PC, and these folder contain some vis with the same as those I require I then get conflicts.
The delete button on Project tool bar is greyed out for these folders, if I try to open one of these phantom vis it is searched for and then opens a box ask me to find it.
These phantom items are not visible in Windows explorer.
When try to use resolve conficts option I cannot select the item I want.
(2,592 Views)
Are there any device drivers or toolkits that were used when the VI's were created in LV 7.1 that you have not installed with LV 2010?
Give a few names that are representative of the "phantoms VI's".
(2,581 Views)
Did you use the mass compile feature in LabVIEW 2010 to convert your 7.1 VIs to LABVIEW 2010? If not please try mass compiling. In LabVIEW 2010 go to Tools»Advanced»Mass compile and select the folder with the 7.1 VIs.
Regards
Will A
William A
National Instruments UK
(2,539 Views)
Are you still having this issue? Have the replies solved your issue?
If you still have questions on this subject please reply here and I will be happy to help.
Kind Regards
Dan Vickers - Applications Engineer UK and Ireland
(2,507 Views)
