LabVIEW 2011 Crash Saving VI with Wait on Async Call
When trying to save bug.vi, I get a LabVIEW crash.  To reproduce this, open bug.vi, connect "cluster in" somewhere on the connector pane, and save.  If that doesn't cause a crash, please let me know!  If it does cause a crash, please tell me how to work around it!
George
Message 1 of 9
(3,314 Views)
Work around using flatten/unflatten to string.  Definitely a bug!
Message 2 of 9
(3,313 Views)
Hi George - Thanks for reporting this! I've reproduced the error and will be investigating it;  I'll keep you updated with any progress made.
Just to confirm- what version of LabVIEW are you running and what OS are you using?  I just want to make sure I'm seeing the same thing as on your end.
Tom L.
Message 3 of 9
(3,284 Views)
Interesting!  About two weeks ago, I submitted some code that used Create Network Stream Endpoint Reader.  If you expanded a Concatenate String function from two inputs to three and wired it, you got the "Sorry for the Inconvenience" error.  A definite bug (reported to and logged by NI).  Fortunately, an App Engineer told me how to prevent the crash -- remove a While loop that was part of the code, edit away, then put the While loop back.  Totally weird!
Message 4 of 9
(3,282 Views)
Hi Tom
I am running LV 2011 32-bit on Win7 64-bit.  I have successfully worked around the issue for now by inserting the flatten/unflatten operation in the wire, but I would like to remove that and save the performance hit, so definitely let me know if anything happens with the issue.
George
Message 5 of 9
(3,276 Views)
This was reported to R&D (# 338146) for further investigation. For now, the workaround you suggested using the flatten to/unflatten from string seems to work well. Thanks for the feedback!
Tom L.
Message 6 of 9
(3,263 Views)
Hello, has any progress been made on this issue? I have a VI I pass a cluster into and get the error cluster out. Everything works fine until I try and collect the error cluster once the subVI has finished. Then when I try and save LabView crashes.
Ed
Message 7 of 9
(3,236 Views)
I reported the original bug, and haven't heard anything back.  I did have a chance to see if the bug was present in the 2012 beta, and it is ...
Let's hope that it's fixed by August!
BS
Message 8 of 9
(3,229 Views)
I have checked in on the bug that you mentioned, and it is scheduled to be fixed in the release version of LabVIEW 2012.  However I can not guarantee that this will fix the bug in your specific applications.
~jp
Message 9 of 9
(3,215 Views)
