LabVIEW 2011 and the USB-845x
Hello there,
I was curious to see if anyone else had the same problem and a resolution to my issue. I have Windows 7 x64 and recently did a clean install of LabVIEW 2011 x64. I have a USB-8451 SPI/I2C card that I am trying to make available to use in LabVIEW. The newest drivers (2.0) say in the readme file that Windows 7 x64 is supported and that LabVIEW 2011 x86 is supported but not x64. I installed and tried it out to no avail. However upon copying and pasting from the Program Files x86 to the Program Files (64-bit) LabVIEW folder, I now have the 845x palette available under the Instrument I/O main palette but everytime I choose one for the block diagram it asks for the location for the ni845x.dll shared library file. The only one I found on the whole system was in C:/Windows/SysWOW64 and I link to that file and now the VI's error out saying the library wasn't found/loaded and am just stuck now. Any help would be greatly appreciated.
(2,624 Views)
The issue has to do with being able to (or rather not being able to) load 32-bit DLLs into a 64-bit process. While the driver readme says that it's compatible for both Windows 7 32-bit and 64-bit, that's not the same thing as saying the DLL is 64-bit. And in order to be able to use it from LabVIEW 64-bit you need a 64-bit DLL. This is an operating system limitation, not a LabVIEW one. Thus, you have to use LabVIEW 32-bit. Your license allows you to install both 32-bit and 64-bit, so unless you have a specific reason to use 64-bit LabVIEW (like you're trying to manage gobs of memory), stick with 32-bit LabVIEW for now.
(2,620 Views)
