LabVIEW 2011 app builder locks up when building packed library or source distrubution.
I have an issue that I was found in bigger project.  I have a situation that I accidentally had a class in another library the same name as the class in a library that I was packing.  The application builder locks up when attemping to build the packed library. As shown in the picture below the class in the library refers to the class outside the library.  I attached an example that I was able to recreate from my big project.
Project Setup:
Results of the "build"
When closing this box the LabVIEW is now locked up.  This dialog does not show a completed build.
(2,477 Views)
Hello mbechtold,
I have been looking into this issue and am able to replicate the hang you are experiencing. I did some more research regarding this issue and found that this is similar behavior to a Corrective Action Report that has already been filled. Do you have DCS installed on your computer?
Paul-B
(2,463 Views)
