LabVIEW 2011 breaks LabVIEW 8.5
I un-installed both LabVIEW 2011 and 8.5.  Then, I re-installed 8.5.  The same "nip2p.dll is missing" error occured.  I deleted all dll starting with the prefix "ni" in the folder system32, but that didn't fix the problem.  Any thoughts on that?
Kudos and Accepted as Solution are welcome!
Message 11 of 14
(878 Views)
We generally do not recommend manually deleting dll files, but the solution mentioned earlier outlined a reinstall of LabVIEW 8.5.1 and (older) DAQmx after doing so. Did you try this step as well?
Zach P.
Staff Software Engineer | LabVIEW R&D | National Instruments
Message 12 of 14
(858 Views)
Yes, I did.  I removed all NI software from my laptop, and I re-installed LabVIEW 8.5 and (older) DAQmx.  I actually installed 8.5 and not 8.5.1.
Message 13 of 14
(843 Views)
The "msiblast" thingy mentioned above should fix up registration.
It looks like the dll is still registered. Try that to cover the steps outlined above.
Ben
Message 14 of 14
(827 Views)
