LabVIEW 2012 fail to open
My LabVIEW 2012 fails to open with a message that says side by side operation is not configured properly.  I tried to open LabVIEW 2011, and it opened and I didn't see the message, but it was very slow as it opened.
Before I see the error, I did a repair on my Microsoft Visual C++ 2010 Redistributable Package (x86) and on my .NET 4.5.  What is the quickest way to fix that problem?
Thanks!
Kudos and Accepted as Solution are welcome!
(2,845 Views)
Accepted by topic author jyang72211
I did a lot of installing and uninstalling surrounding the Microsoft Visual C++ distributable, and that didn't fix the problem.  I also did a repair for the LabVIEW 2012.  Later, I look at the event log, and that pointed me to the LabVIEW.exe.config file.  I made the following change below, and that fixed the problem.  I am not sure why though.
LabVIEW.exe.config that caused error
<?xml version ="1.0"?>
<configuration>
<startup useLegacyV2RuntimeActivationPolicy="true">
<supportedRuntime version=""v4.0.30319""/>
</startup>
</configuration>
LabVIEW.exe.config that fixed error
<configuration>
<supportedRuntime version="v4.0.30319"/>
</startup>
</configuration>
(2,798 Views)
