LabVIEW 2012 install error
Hello guys,
I need to install LabVIEW 2012 on my computer(windows 7 32 bit), However, when I clicked the setup.exe. A window popup to install the Microsoft.NET framework 4.0, After then, another window popup to show an error occured when installing Microsoft.NET framework 4.0. Is LabVIEW 2012 conflict with window 7?  There is an thread discuss about this issue. The suggestion there is reinstall the OS. For the terget PC here, reinstallation of the OS is not an option. Is there any way to go over the installation of Microsoft.NET? or any other suggestion? Thanks a lot!
(3,128 Views)
Any suggestion?
(3,125 Views)
Accepted by topic author phyyu
just post the update here.
Microsoft .NET need to be installed seperately here. After that has been installed, the installation of LabVIEW 2012 could move on...
thanks
(3,118 Views)
