LabVIEW 2013 Fpga will not compile tutorial solutions
Y'all
I am working to get the CRIO evaluation software to compile the tutorial solutions.  so far it will not and complains about missing XILINX_EDK (warning.)  Attached is the xilinx log.     (Do I need to reinstall? or what)
Thanks for help!
Sincerely,
Paul
(3,022 Views)
Hi Paul,
What version of LabVIEW (2013/2013 SP1), LabVIEW FPGA and Xilinx Compile Tools do you have (or are you compiling on an external server)?
Which example specifically are you trying to compile? You mentioned tutorials, but I'm not sure exactly what example you are referring to.
Thanks!
Xavier
(2,980 Views)
