LabVIEW 2013 SP1 Quit LabVIEW
Mr. Eidloth,
Would it be possible for you to send me the Build-Folder you generated including the GUIDemo.exe?
Thank you very much.
Regards.
Veronika Kurz
Applications Engineering
www.ni.com/support
Message 21 of 53
(1,765 Views)
Hello Ms. Kurz, I forgot, for this PC we used a image of another PC with LV2011. The EXE folder is attached as ZIP. Regards Heinrich Eidloth
Message 22 of 53
(1,757 Views)
again with attachment
Message 23 of 53
(1,755 Views)
third try
Message 24 of 53
(1,753 Views)
Message 25 of 53
(1,750 Views)
Hello Mr. Eidloth,
Could you please try running the attached exe and let me know if it works properly?
Regards
Veronika Kurz
www.ni.com/support
Message 26 of 53
(1,741 Views)
I´m sorry. The file has to be converted from .txt  back to .exe because the transfer via zip does not work.
Veronika Kurz
www.ni.com/support
Message 27 of 53
(1,751 Views)
Hello Ms. Kurz, I just tested it on my virtual machine, and it woked as expected. Regards Heinrich Eidloth
Message 28 of 53
(1,746 Views)
I don't have a solution (I'm sure NI is investigating) but I do have a work around.  Attached is a VI that I use to stop or Exit LabVIEW.  This is a very common feature and has been reproduced alot.  My version adds an optional Taskkill of the application.  Run this VI at the end of your application, after you are sure all clean up has finished, and all references have been closed.  Then wire a True to the Task Kill EXE terminal which is False by default.  Note that this taskkill only will be commanded if you are in a built application and not while running in source.
Message 29 of 53
(1,733 Views)
Hello Hooovahh,
thank you for posting the Workaround.
Hello Mr. Eidloth,
I will contiune looking into the case and hope I can get back to you soon with a solution.
Unfortunately I will be out of the office tomorrow and on Monday.
Please excuse the delay.
Regards
Veronika Kurz
www.ni.com/support
Message 30 of 53
(1,712 Views)
