LabVIEW 2013 Window Appearance
This is a known behavoir when all of the above parameters are set and window is at the minimum size when run is pressed having the window larger than minimum size removes the white bar.
It was discussed here, shortly after LabVIEW 2013 was released.
- FCTesting
Message 11 of 14
(1,784 Views)
Thanks for sharing the link!
I installed the f2 patch which still did not solve the problem.
Message 12 of 14
(1,756 Views)
Set the minimum size to 0,0 in the VI properties and everything works fine.
(Since you don't allow resizing, hide the scrollbars, and define a run time position and size, setting a minimum size is irrelevant, but seem to coerce the size too large in 2013 due to some new buglet.)
Message 13 of 14
(1,746 Views)
I recently posted a similar thread:
http://forums.ni.com/t5/LabVIEW/window-glitch-in-LabVIEW-2013/m-p/2780280/highlight/false#M817734
At the time I posted, I did a search but didn't come across this thread.  So I figured a cross-post would be useful to try to tie these together.
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
Message 14 of 14
(1,626 Views)
