LabVIEW 2013 getting worked with LeCroy WaveRunner 8054
Hello everyone,
I am using LabVIEW 2013 on Win7. I am currently looking for a driver for a oscilloscope.
I want to use the LeCroy WaveRunner 8054. Therefore I need some drivers.
Does anyone know, if there is something to get the oscilloscope working with LabVIEW 2013 ?
Thanks a lot!
(2,749 Views)
Hi Soleil,
you should search the IDNet: there are some drivers for other WaveRunner devices.
Or you ask LeCroy for LabVIEW drivers…
(2,745 Views)
Hi GerdW,
thanks for the hint!
I already searched through it. But I am not sure, if these drivers will work, due to the older versions of the WaveRunner Series.
Soleil
(2,741 Views)
Accepted by topic author Soleil20
Hi Soleil,
Then you need to read the manuals of the older and your newer device and compare them.
Most often the commands don't change so much, you only need to check for new options of your newer hardware…
(2,731 Views)
