LabVIEW 2014, smtp example sends no mail
I have a strange problem, I want to send an e-mail by using the SMTP (IP address is known) example without authentification. The vi "Send Email using SMTP Client_LV2014.vi" works without error, but no e-mail is generated by the server. With the same settings I use the old smtp tool of labVIEW 8.6. "EMail with Data_LV8.6 converted to LV2014.vi". this works fine even under LabVIEW 2014 and I receive the generated mail within seconds. Can someone help? Attached are both VIs.
In both cases I used my e-mail address for sender (return address) and receiver and I used the IP number of our mail server (plus port 25 at the LV2014 vi)
Will it help to use an account with login?
best regards
Joerg
Message 1 of 1
(2,501 Views)
