LabVIEW 2014 x64 AppCrash StackHash crash
@jojo_mcbean wrote:
I'm having the same error. Labview crashes after 10-30 minutes of running. Did anyone figure this one out?
The error described in this thread is definitely not specified enough that anyone even a very versed LabVIEW user could claim to run in the exactly same crash. Unfortunately just because your software crashes, this doesn't mean that it has the same reason than the umtien million other possible crashes that can happen.
Open a new thread, attach as much as possible information about your crash including OS, LabVIEW and any driver versions that your app uses and work from there. And if you have a LabVIEW maintenance support contract, call technical support and work directly with an Application Engineer on your problem.
Rolf Kalbermatter  My Blog
Message 11 of 13
(1,682 Views)
Basically NI confirmed that they could reproduce the crash once we gave them our software.  They were going to pass it on to the LabVIEW developers so they could trace into the run time and figure out why it's crashing.  So, no, no solution other than the figure out what code of yours is triggering this bug and then work around it.  In our case, it seemed like Queues of clusters created in dynamic processes where involved.
Message 12 of 13
(1,666 Views)
I also recieved a similar error. How helpful is the additional information section?
Problem signature:
Problem Event Name: APPCRASH
Application Name: My_App.exe
Application Version: 1.0.0.1
Application Timestamp: 52cf1e34
Fault Module Name: StackHash_5861
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: PCH_72_FROM_ntdll+0x000735D4
OS Version: 6.3.9600.2.0.0.768.101
Locale ID: 1033
Additional Information 1: 5861
Additional Information 2: 5861822e1919d7c014bbb064c64908b2
Additional Information 3: 4754
Additional Information 4: 47547fafc9a3073a5bbe8e69322a8db5
Message 13 of 13
(1,482 Views)
