LabVIEW 2015 - IMAQ codec issue
I have problem with processing AVI file with such kind of specification (taken from ffprobe):
Video: mpeg4 (Simple Profile) (mp4v / 0x7634706D), yuv420p(pc), 640x480 [SAR 1:1 DAR 4:3], 3141 kb/s, 25 fps, 25 tbr, 25 tbn
When I try to open this file I get error:
Here is response from "get codec names" component:
I have LabVIEW 2015 (32-bit) and Windows 7. It's similar topic here. Anyway it doesn't solve my problem. It's looks like I don't have proper codec for my file. What should I install? I guess MPEG-4 V4???
(1,887 Views)
Hello maciej_fajfer,
Try to understand which codec was used for creating your AVI, because error said that there is no appropriate codec for processing.
Find that codec where/whom you got this AVI from and install it.
(1,846 Views)
Thank you for your response. It's looks like I have proper codec but LabVIEW can't find it. This AVI file works perfect under Windows with for example Windows Media Player. There's also second issue with large AVI file (about 2 GB). It's sometimes give frame reading error. Due to that I don't use "AVI open" and so on. I've found this: https://forums.ni.com/t5/Example-Program-Drafts/Labview-MP4-Video-File-Read-Write/ta-p/3976751 It works perfect with IMAQ and I can read AVI and MP4 files. Anyway I had to edit "ffmpeg_VideoSize.vi" file because there was some issue with LabVIEW 2015.
(1,835 Views)
