LabVIEW 2015 SP1 - LabVIEW Pro installed (and activated) but treating users like LabVIEW Full.
Has anyone heard of this issue before?
Thanks!
Bill
CLD
(Mid-Level minion.)
Message 1 of 13
(4,600 Views)
I guess when you say "activated" it must be local licenses?  We use network licenses here and have seen a similar problem.
Our Full Dev System network licenses are "unmanaged concurrent".  The Pro licensed users have to disable the license request for a Full license type in the license manager to skip it and check for a named user Pro license.  Otherwise they only get a Full license.
The LabVIEW startup screen shows which level of license has been obtained.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 2 of 13
(4,549 Views)
That scenario sounds suspiciously like what I've found to be the case with our licenses.  I'll have more info next week.  (Off tomorrow.)
Bill
CLD
(Mid-Level minion.)
Message 3 of 13
(4,547 Views)
I would recommend looking at NI License Manager to see how your software is being licensed.
Is this a local license? Network? Both?
Are there competing licenses that are trying to activate this software?
What behavior (specifically, if possible) are you seeing that prompted this forum post?
Is this a new installation? How long has this behavior been occurring?
Local licenses can sometimes block volume licenses, even if the server is correct.
Kevin S.
Technical Support Engineering
Message 4 of 13
(4,515 Views)
Yes, it bit me in the behind a few years ago.  I forgot what "Professional" parts I was using, but it was strangely missing.  I called NI, got a very nice (they all are, in my experience) AE, who listened, walked me though the process, we opened License Manager and he asked what was activated.  I said "Full" (and more-or-less remembered doing that instead of Professional, since I really didn't completely understand the distinction), and once I clicked "Professional", problem was solved, my face was red (but we weren't using VideoPhones), and I Learned my Lesson ...
Bob Schor
Message 5 of 13
(4,492 Views)
Sorry for the late update.
It seems that, at some point in time, there existed a license server.  (I see an entry in the server.ini that corresponds to what a trusted source tells me is a general license server, but hasn't been used for LabVIEW in forever.)  Now that the server has been out of the picture for well over 14 days, I expect the backup license has "expired".  (See Backup Licenses and Expiring Activations in NI Package Manager.)
What I am seeing is that I try to install a local pro license.  About LabVIEW shows it as "Professional" but it acts like "Full" for all users.
After searching far and wide, I feel like we have conflicting license issue here.  Can the expired VLM interfere with local licenses like this?
Bill
CLD
(Mid-Level minion.)
Message 6 of 13
(4,455 Views)
Does it still happen even when you remove the reference to the license server in the License Manager?
[License Manager 3.7] Options > Preferences > {untick "Use Volume License Servers"}
[License Manager 4.2] Menu > Manage Volume License Servers... > {clear the text field}
Message 7 of 13
(4,445 Views)
I was so hopeful!  I used method 2 to clear the text field but it didn't work.  I then deactivated LabVIEW + everything else listed and reactivated them with the pro license and it did not work, either.  Dang, I thought this would work!
Bill
CLD
(Mid-Level minion.)
Message 8 of 13
(4,439 Views)
Last attempt, close all the NI applications down and delete this file:
%ProgramData%\National Instruments\License Manager\Data > servers.ini
Then start the license manager again.  That was one of the debugging steps I went through with NI support when we were having license problems last year.
Doc ref here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PmvSAE
and here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8cESAS
Maybe this will help too...
How Do I Stop NI License Manager Requesting Particular Software?
Message 9 of 13
(4,435 Views)
Unfortunately, closing all the NI apps and deleting the server.ini file didn't help.  I then deactivated everything that was listed as activated, rebooted and added them back.  That didn't work, either.
Bill
CLD
(Mid-Level minion.)
Message 10 of 13
(4,419 Views)
