LabVIEW 2016 Run time error 127
Already Built with default settings as you recommended.
Have you or anyone else on this thread tried to run my simple exe file posted above?
Message 11 of 14
(2,347 Views)
Can now confirm that it will not run on other Windows 10 machines.
Message 12 of 14
(2,332 Views)
Hi Carsten,
I have run your miniVI.exe on my Windows 7 machine, with LabVIEW 2016 (64-bit) development suite and it works. I don't have access to a machine without dev suite right now to test that for you.
Message 13 of 14
(2,325 Views)
Accepted by topic author CarstenPXI
I get the feeling it works fine you have have a development suite installed on the target machine.
I called NI Support last week, and the first thing they asked me was "Why did I want to use 64 bit?", and told me that it generally was only recommended for vision applications.   So I rolled back to 32 bits, and everything works.
I think it behoves NI to recommend more caution on their 64 bit "Considerations" notes, I wasted way too much time trying to get something to work that doesn't.
Case Closed.
Message 14 of 14
(2,295 Views)
