LabVIEW 2016 executables
Hi
I have installed LabVIEW 2016 from 2015.  However, when I deploy my project it fails to run.
After a bit of debugging, I found it is because of Application.Kind.  Instead of Application.Kind returning 'Run-time' it is now saying 'invalid app kind'.  Is this a known issue?  Is there a better way of determining the path?
Thanks, Seán
(4,201 Views)
Accepted by topic author SeanJ
In 32-bit LV2016, it is working for me.  Do you have the error cluster wired up?  If so, an incoming error would result in this returning invalid app kind.
(4,161 Views)
Oops!
You are correct, I was looking at the second call, two files need to be loaded.
Seán
(4,139 Views)
