LabVIEW 2017 32bit won't launch on Redhat Linux 7.5
I am running Redhat Linux 7.5.
I had successfully installed LabVIEW 2018 64bit, but I actually need to install LabVIEW 2017 32bit, so I uninstalled LabVIEW 2018 64bit (not sure if this corrupted something). I also have NI-KAL and NI-VISA 15.0 installed as well as the latest kernel-devel drivers.
I ran through the same installation instructions and did not receive any errors during the installation. However, when I click the labVIEW icon it will not launch. When I try to run LabVIEW 2017 32bit using sudo from the terminal, I get the following error message:
$ sudo ./labview
./labview: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
Does anyone know how I can fix this error?
Thanks.
(2,669 Views)
Accepted by topic author JHugh
Hi.
This month we released some drivers for linux, you can check the list of the supported ones below.
http://www.ni.com/product-documentation/52786/en/
It seems to be that your version of NI-MAX is not included on the list. But with the LabVIEW issue a possible workarround could be to completely unistall the LabVIEWs versions that you have and try again, but that can have unexpected behaviors.
(2,632 Views)
