LabVIEW 2017 Crashes
Today I started to have some weird problem with my environment. In about 5 hours I've got 36 crashes! How can I found the cause?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,748 Views)
You could start by describing your problem in more than two sentences.
Bill
CLD
(Mid-Level minion.)
(2,718 Views)
Laconic because it crashes randomly, no consistent behavior. Some of the cases:
Build in quick drop W (connect nodes),
Saving VI,
Placing constant on the diagram,
Connecting error cluster to the VI,
Moving label on the diagram,
Placing build array on the diagram (with a quick drop),
etc.
As you can see nothing special.
In my project, I use a couple of classes (which based on my experience likes to make LV crash), math script node and a couple of formula nodes. I thought that formula nodes or math script might be a reason for crashes. So, I replaced formula nodes and surrounded math script with disable structure (so it should not be compiled). I cannot get rid of classes. After my changes problem does not disappear.
Can UseUnicode=True in LabVIEW INI be a problem? I was experimenting with this some time ago. But my problem appeared today. However, I had some label on the diagram and the text inside was in Polish. The first crash appeared when I moved this label and the VI, inside I move it, was empty.
After today's battle with LV2017 I moved with my work to freshly installed LV2018 (no playing with LabVIEW INI) and the label, I mentioned, was definitely wrongly rendered (the text goes outside the label frame). I was able to work normally with the same code.
Michał Bieńkowski
CLA, CTA, CPI
(2,703 Views)
