LabVIEW 2019 64bit failed to start on win7sp1 64bit
I have both LV2019f2-32bit and LV2019f2-64bit installed on Win7sp1-64bit OS. LV2019f2-32bit starts OK. However LV2019f2-64bit shows the starting picture for a moment and then quits/crashes without any messages.
How can I solve this problem?
Thanks.
WT
(3,038 Views)
Attached please find the log file.
(2,997 Views)
Have exact the same issue. By stealing the
...\LabVIEW 2019\resource\Framework\Providers\mxwProjectProvider.mxx
which is nothing else than a dll it gets to run.
But I have no clue what module this is and what it does.
As far as I can see in Debugger there is some GUID string with
zeroes and this leads to 'module not found' exception.
Don't know what the hell is going on.
(2,966 Views)
Thanks.
I solved it by remove some plugin packages, leaving only LV2019. Then it starts OK.
WT
(2,946 Views)
OK, wich were the packages you removed ? - if this
is better known I could do some more investigations and
then file a support request at my ssp for the NI team
to solve that nasty bug.
(2,929 Views)
Hi Gprogrammer
I don't remeber all the packages I removed. I only remember some of them like Database conncetor, Report generator.
I only left these packages now, see the snapshot.
WT
LV2013-2019
(2,895 Views)
