LabVIEW 2020 SP1 community for Mac
Has Anyone encountered this message while setting up LabVIEW 2020 SP1 community for Mac on macOS.
“LabVIEW 2020 SP1 Community 64-bit” can’t be opened because Apple cannot check it for malicious software.
This software needs to be updated. Contact the developer for more information.etc
(1,668 Views)
Here's what I found when reading the "Readme" webpage that you can open from the installer:
Note  If you download the installation image from ni.com, you may run into a macOS warning when you double-click the installer to run. Instead, right-click the installer and select Open. When you see the warning message, click Open to run the installer and proceed with the installation.
Hope this helps. Just right-click instead of double-clicking.
(1,594 Views)
