LabVIEW 2020 Security Warning: Run When Opened
Using LabVIEW 2020 and TortoiseSVN. I have TortoiseSVN configured to run with LVCompare for Diff viewing. Every time I try to perform a diff, I am met with the following security warning. Honestly, the security warning is a great idea for shared code, but I am wondering if there is a way to whitelist certain VIs. Having this pop up every time I diff disrupts my workflow.
(3,292 Views)
That's funny - I just had this start happening to me a week ago, maybe something like that?  It was working fine, then I had to uninstall/reinstall the ViewPoint TSVN toolkit and tell it to use LVCompare for diff/compare.  After that, I had the problem.
Unfortunately for you, my post wasn't helpful to you, except to confirm someone else saw it.
Bill
CLD
(Mid-Level minion.)
(3,265 Views)
Isn't there any way to go around this warning to auto start a vi during the boot sequence?
Larsemann
(2,985 Views)
