11-04-2025 08:51 PM
11-05-2025 11:24 AM
By itself, LabVIEW 2022 claims to be compatible with server 2019:
That would at least suggest that anything that's not working may not be related to LabVIEW itself, but possibly anything external it works with.
Can you provide more information about what the application does?
Anything that meets one of the above categories is more likely to point to a problem other than it just "existing" on Windows Server.
Is your application built in a way you could disable large portions of it to see if certain parts of it running make it slow down while other parts don't?
