LabVIEW 2023 Q3 TDMS write error. LabVIEW: cannot load the USI components the Storage/DataPlugin VIs require.
I opened the built in example "TDM Channel Groups.lvproj" in my LabVIEW 2023 Q3.
When I run the Write TDM Channel Groups.vi I got the following error:
Error -2560 occurred at Close Data Storage
LabVIEW: (Hex 0xFFFFF600) LabVIEW cannot load the USI components the Storage/DataPlugin VIs require.
These components are installed by LabVIEW and DIAdem.
I checked in my NI Package Manager, I found the NI USI core is Installed:
then I tried to install LabVIEW DataPlugin SDK.
Still Got same Error.
Any idea?
(2,751 Views)
installed the Update LabVIEW 2023 patch 2.
Everything looks fine.
(2,700 Views)
Just Noticed that Writing to TDMS files works fine. But not for TDM file.
write to TDM file keep saying the same error -2560
(2,600 Views)
Why the USI core (LabVIEW DataPlugin) become unstable?
sometimes works fine, and sometimes not with Error -2560 "Cannot Load the USI Components …"
And when the error occurs, the DataPlugin List in Open Data Storage Configuration is blank, as bellow:
I've recently repairing the USI core in NI Package Manager.
Still not fixing the issue yet.
Any one experiencing the same?
(2,525 Views)
