LabVIEW 2025Q3 .NET core memory leak!
This is consistent even with built-in .NET functions.
See the attached VI where it's just generating some GUIDs.
It takes almost 2 orders of magnitude to run the .NET Core version.
You can see the memory drift as well if you have Process Manager open.
Message 21 of 26
(529 Views)
@jyoung8711 wrote:
Just an FYI the latest patch : 26.1.1.49193-0+f41 (released this week) did NOT fix this issue 😞
According to patch notes memory leak got already fixed with latest patch Bug Fixes 26Q1
CLA
Message 22 of 26
(471 Views)
There's another post about this where someone from R&D (I think) chimed in and said they thought it was fixed, and that they did some memory optimization... I think they missed the core issue though 😞
The patch notes were not posted when I did my initial testing.
Message 23 of 26
(460 Views)
I’ve finally had time to test the memory leak issue again.
=> The problem is still there 😞
The memory leak is slightly less severe, but it’s still there. Come on, NI!!!!!!!!!!!!!!
What can I say? Does NI understand the "definition of done"?
CLA / CTD
Message 24 of 26
(372 Views)
Sometimes you think it's fixed but it's not. If you are a CLA you should know this.
Bill
CLD
(Mid-Level minion.)
Message 25 of 26
(339 Views)
Unrelated and a complete sidenote, but NewGuid is a static method and does not require a constructor node.
Message 26 of 26
(286 Views)
